It's a parameter adjustment in a menu on the screen. The temperature control adjusts the temperature (unsurprisingly) whereas range rating adjusts the maximum power output. It's a case of reading the installation manual usually
Fair do’s, thanks for explaining that,...it makes sense, even to me!It's a parameter adjustment in a menu on the screen. The temperature control adjusts the temperature (unsurprisingly) whereas range rating adjusts the maximum power output. It's a case of reading the installation manual usually
My most recent post (last week) was about my sons combi boiler problems,..now sorted thankfully;...however, my daughters (very old!) conventional boiler has just packed in,...again!...it needs replacing,...never rains but it pours.
She’d prefer a replacement conventional boiler (not a combi) as she likes her airing cupboard and power showers. She uses lots of hot-water. It’s a largish 3 bed detached house with 2 bathrooms.
For aesthetic reasons she wants a conventional boiler that will fit neatly inside a 30cm deep kitchen wall cupboard.
I had a large kitchen extension/renovation completed 2 years ago and I had my old boiler replaced with a (conventional) Baxi424 boiler. I'm really impressed with it;...it’s completely tucked away inside a standard kitchen wall cabinet and it’s whisper quiet in operation. All the piping is neatly hidden away and unless you open the cupboard door you’d never know it housed a C/H boiler.
However, things move on. Any up-to-date boiler suggestions or ones you think are best avoided?...any other suggestions/advice?
She’ll pay cash for the new installation,...doesn’t need a finance package or similar.
As ever, all replies gratefully received. Thanks in advance.
No, your boiler is about a basic as they come, it can't be adjustedFair do’s, thanks for explaining that,...it makes sense, even to me!
I’ve just had a search through the installation/service manual for my Baxi424 and there is no mention of range rating, or any parameter screen/adjustments.
The front panel has a temperature control bezel, a re-set switch and something called the ‘chimney sweep button’. Would the ‘chimney sweep button’ have something to do range-rating?...or can I assume that my Baxi424 doesn’t have ‘range-rating’ capability?
My boiler is due its annual service so if something needs tweeking I'll ask the engr to check/adjust if necessary.
Is that a good or bad thing?....in as much as very little to go wrong?...My previous Potterton conventional boiler ran sweet as a nut for 25 years and hardly spent a penny on it in all that time. If my Baxi lasts that long I’ll be well pleased,...assuming I’m still around.No, your boiler is about a basic as they come, it can't be adjusted
As I stated in my thread starter.."all replies gratefully received."I work for a manufacturer, would you like a suggestion for a biased source?
You won't be so impressed with that 424 when it breaks down outside the warranty period - they're extraordinarily expensive to repair.
What make/model boiler does your daughter have now? Has a heat loss calculation been done to determine the heat requirements for the property? If not, that's the first step. Look at www.heat-engineer.com for a good heat loss calculator. Can't recommend a boiler until we know what power is needed
Gas approx 18,000Kwh per year.I wonder if an heat loss calculator, might work even better, if there was some input from present actual annual consumption? I ran through the above calculator for my home - It came up with an annual Kwh some 20% higher than we actually used, with just the boiler, gas hob and double gas oven consuming gas - so the 20% high would be even more.
A bit like old cars Vs new cars then.Yes, the less complex the boiler, the less there is to go wrong and the easier they are to fix when they do go wrong - but you pay for it in less comfort and extra gas consumption.
The lower a boiler can modulate its output down, the more efficiently it will run once the demand has been matched. Being able to reduce it's heat output to low value, avoids it constantly cycling, plus that extra wear and tear of constantly firing up.
Thanks for that Harry;...could you please qualify how ‘less comfort’ would manifest itself?
