Do you have an expert view? At present it seems to be 2:1, but you could make it a draw if you were inclined to side with flameport.Good luck flameport
Kind Regards, John
Only if, as per the OP's diagram , the wall unit goes up to, or very close to, the ceiling.Yes that's ideal, just on the fixing point for the wall unit !
Are you saying that all of the cables (or conduit containing them - which isn't really necessary) below counter level will be 'on the surface' and visible?
What Simon35 proposed was as shown in the blue line I have added here:
Provided the horizontal run at the top was within 150mm of the ceiling, that would be compliant.
Kind Regards, John
It's not a common arrangement but it can be done.I was also led to believe that taking a spur from the cooker switch / radial circut / connection was a big no no
Yes. Even if the flex is not visible.May I ask If I run a spur off the MUCH more accessible upstairs ring circut, drop it down to within 150mm of the ceiling and install the FCU there, have the flex cable visible between the FCU & the chimney and the rest of the flex to run down within the chimney to it's electrical connection
No, it's obviously not a game, although your "Good luck flameport " comment seemed to suggest that you were trying to turn it into one. The OP is faced with conflicting views about flameport's suggested solution, and I'm sure he would therefore value further views, particularly from experts.You think this is a game ? Someone has asked advice and you treat it as a point scoring game BH.Do you have an expert view? At present it seems to be 2:1, but you could make it a draw if you were inclined to side with flameport.Good luck flameport
Not so, so there would be the ideal method if your cooker switch were in the correct position above the worktop.I was also led to believe that taking a spur from the cooker switch / radial circut / connection was a big no no
Fair enough. That being the case, and given the differences of opinion you have seen about safe zones, you're probably right in saying that your best solution is probably to supply the hood 'from above'.Wiring the way Simon35 has proposed would not be possible as the wall units are already fixed on and I don't believe the units will go back on as securely again the second time round
That would work - although, if the OP's diagram is accurate, I can't really see how the FCU would not be visible.Up from cooker switch to FCU at the top of a wall unit (not visible from floor), horizontal to connector unit behind hood chimney.
No, if I had wall units (which I don't!), I probably couldn't - but the OP's cooker switch is not (per his diagram) under the wall units.Can you see on top of your kitchen units?
... would not be possible as the wall units are already fixed on and I don't believe the units will go back on as securely again the second time round
(There is no point having it out of sight. It is for emergency switching.)
I'm not really sure why you are re-posting that but, as I said, if I now understand correctly what you are proposing there ...Not so, so there would be the ideal method if your cooker switch were in the correct position above the worktop.I was also led to believe that taking a spur from the cooker switch / radial circut / connection was a big no no
