Looking at a son-in-law replacing a cooker on a MCB 32A with a RCD in the CU block.
CU Replaced 2019
I'm sure its 6mm cable going to a Cooker Switch.
They want temporarily 2 single ovens. rather than a double oven.
I suggested 2 13A either with a PLUG or Hardwired rated at 13A
then from existing cooker switch a 6mm cable radial into 2 seperate single sockets.
Cable uncliped in open 47A , MK single socket 20A and spec says each screw terminal will take 2 6mm cables
However some of the cookers still say 13A fuse , BUT hardwired
In which case instead of the Sockets , just add 2 switched 13A Fused Spur
CU Replaced 2019
