I did look at the current rating for double sockets, it seems down to make and model. Found some rated at 13A a pair and others 13A each and both were MK.
When 17th came out I looked at alitube cable with the idea of fitting RCD at end of cable rather than at the start of cable run, however the problem is cost, and RCD sockets are expensive and so is alitube so very quickly one realises no real option but to swap consumer unit.
In my other house I don't have a consumer unit as yet, just two fuse boxes, both fed from a RCD it was done before distribution boxes with built in RCD's were around, but today to get metal boxes for add on RCD's would not be much cheaper than a problem consumer unit, and today distribution boxes for use by general public should be type tested.
I suppose there is nothing stopping anyone fitting a CU and doing all sorts of other work which does not comply with the law, however it only causes problems latter so may as well get it all done with correct paperwork to start with, there is a good reason why you should not DIY a consumer unit change, it is dangerous.
