http://www.ewnews.co.uk/index.php/hamilton-takes-a-fresh-look-at-circuit-protection/I would have thought that they are probably quite pleased that they can use an abomination of a regulation as a means of increasing their profits!
Maybe - but as I've just written, I wonder what they are made out of.In domestic property certainly.Anyway - does this mean an end to the good old 800KMF?
They look/sound nice and cheaphttp://www.ewnews.co.uk/index.php/hamilton-takes-a-fresh-look-at-circuit-protection/I would have thought that they are probably quite pleased that they can use an abomination of a regulation as a means of increasing their profits!
No point quoting that - it is meaningless.
That would be reasonable were it not for the fact that they make it explicitly clear that, as far as they are concerned (and hence as far as the reg is concerned), ferrous metal "is" (although we all know that it isn't!) "an example of a non-combustible material". That being the case, it is possible to comply with what they have written (in the regulation) by using a CU with a ferrous metal enclosure.As far as I am concerned, if they create a regulation which is impossible to comply with one is perfectly entitled, in fact one has no choice but to, ignore it.
I'm afraid that "as far as they are concerned" does not have the right magic powers to change the physical properties of materials, the laws of physics etc.That would be reasonable were it not for the fact that they make it explicitly clear that, as far as they are concerned
But they are wrong, and therefore everything predicated on that mistaken belief is also wrong. 421.1.201 is invalid.(and hence as far as the reg is concerned), ferrous metal "is" (although we all know that it isn't!) "an example of a non-combustible material".
No it is not.That being the case, it is possible to comply with what they have written (in the regulation) by using a CU with a ferrous metal enclosure.
Adding "until specific standards are identified" does not magically change the properties of materials.
Indeed - and, as I've said, I believe that is the effect of the wording they have used. They have made it very clear that a ferrous metal CU would be compliant with their new regulation, but have left it anything-but-clear as to what other materials would also be compliant (although they at least imply that some other materials would be compliant).I'm not saying it does. If you read what I wrote again, you'll see that my wording DOES NOT deem non-ferrous metals to be non-combustible. They cannot do that - as you say, they don't own the laws of physics. They CAN however, deem a CU made of non-ferrous metal to meet the requirements of a specific regulation which they DO own.
They can't. However, they can deem that a CU made of a particular material would be compliant with their regulation - and I would imagine that any Court would conclude that such is the effect of what they have written (in relation to ferrous metal).They cannot deem themselves into changing the nature of materials, it doesn't work like that.
A quick bit of Googling suggests that it may be around 816°C.So, BAS, if steel is combustible, what's the ignition temperature?
I would imagine that 816°C (if that's the correct figure) is far from unknown in domestic fires.And how would you expect to reach that temperature in a fire?
No, they can't, because they have said "non-combustible". Once having said that they do not have the power to magically declare something non-combustible when it is not. Science and engineering do not work like that.They CAN however, deem a CU made of non-ferrous metal to meet the requirements of a specific regulation which they DO own.
No, they can't, because they have said "non-combustible". Once having said that they do not have the power to magically declare something non-combustible when it is not. Science and engineering do not work like that.They can't. However, they can deem that a CU made of a particular material would be compliant with their regulation
