Hi all.
I've just removed an internal brick wall adjacent to my mains fuse, meter, and earth connection. I've now noticed that the main earth cable clearly took a bash - despite being as careful as I could. There is a nick in it, which has gone through the insulation and has broken (at least) a few of the strands of cable, but it is difficult to see how many. The cable is a 10mm sq cable. It is safe to say that at least half of the cable is intact - probably more.
My plan was to replace it entirely, but having taken up the floor to do this, I can now see it disappears down a hole under the outside wall alongside the blue plastic water main, so I can't get to the source connection.
My alternative plans now are:
a) Wrap the nick in the cable with insulation tape and leave it at that.
b) Make a joint in the cable to replace the damaged section.
If b), what connecting method should I use? I have some 30A j-boxes already, would they be any use for this?
Many thanks in advance.
