Make of it what you will
411.3.1.2(iv)
411.3.1.2(iv)
411.3.1.2(iv)
Why is this reasoning not applied to the water and gas installations?Central heating in that instance would refer to systems installed in block of flats, where heating pipes from a central boiler pass through all of the flats.
Or perhaps where waste heat from power stations is used to heat a local housing estate.
411.3.1.2 is considering main protective bonding so does not mention these items. It does mention connecting to the main earthing terminal - central heating.411.3.1.2 does not apply to radiators, pipes and a boiler in a normal house,
because none of those items will be extraneous conductive parts.
Really ?
(iv) Central heatingRead it again. It says "In each installation main protective bonding conductors complying with Chapter 54 shall connect to the main earthing terminal extraneous-conductive-parts including the following:"
Are you saying radiators, pipes and boilers can never be extraneous-conductive parts?Do you actually understand what an extraneous-conductive-part is, and what causes it to become an extraneous-conductive-part?
I agree 411.3.1.2 does not apply but do you agree with the rest of it.411.3.1.2 does not apply to radiators, pipes and a boiler in a normal house, because none of those items will be extraneous conductive parts.
