It's a reactive test - if your installation is on point then your are competent
By the way what's regulation 3(1) - easy for your to find?
should have qualifications
No in your quoted text, it goes on to say that if you make money out of it then you must be qualifiedSo no-one needs any qualifications?
Believe you me, they think very long and hard about these laws - should was put there with good reason, it's not an oversight
I don't want to get into personal opinion, what I think is really irrelevant when it comes to what's legal. If what you're quoting isn't the law then does that mean Joe is legal? if not, then what law is he breaking?ACOP's are guidance, not the law.
"This Code has been approved by the Health and Safety Executive, with the consent of the Secretary of State. It gives practical advice on how to comply with the law. If you follow the advice you will be doing enough to comply with the law in respect of those specific matters on which the Code gives advice. You may use alternative methods to those set out in the Code in order to comply with the law."
If you ignore the training requirements because it says "should", how else will you demonstrate the required knowledge and competence? I don't think, "well I didn't blow the house up m'lud so I must be competent" would be enough.
well let me ask you your own question. why do you think they have said should have qualifications instead of must have qualifications?Did you read my quote in your post? How will Joe demonstrate competence if he ignores the training requirements in the ACOP because it says "should"? The law requires you can work on gas appliances only if you are competent.
The ACOP says "You may use alternative methods to those set out in the Code in order to comply with the law". What alternative methods could he use?
Gas work should only be undertaken: (a) by a person who has successfully completed an industry recognised training course followed by assessment of competence. Training that leads to assessment of competence in safe gas work should be recognised by the industry’s standards setting body
