to comply with which law? what is the law you need to comply with?Because it is advice on how to comply with the law, I've said this a few times now.
If you do this then you have demonstrated compliance with the law......
But the ACOP says, "You may use alternative methods to those set out in the Code in order to comply with the law".
So what alternative method will Joe use to comply with the need for competence?
