- Joined
- 22 Jan 2007
- Messages
- 22,901
- Reaction score
- 3,070
- Country
Because you can't.
Yahoo it, the explanations are out there.
Because you can't.
He doesn't need to, I've just done it for him.Because you can't.
****troll alert****No you didn't.
Yep, he's back. How long before the mods cotton on to him?****troll alert****
was previously known as blizzo and MGM
As I've said so many times, it may not be the variant that we need worry about, it's the next variant that could really cause some damage.If you haven't had a vax, there's a much weaker case for getting one now.
Omicron was found in SA to protect better than Delta.
Omicron isn't very bad if you do get it - or have already had it without knowing.
Delta's gone.
Omicron's going
So what's the vaccine protecting against now? Stroppy tennis batters?
You will have read the "deaths of " versus "deaths with" commentary, I assume - careful what you (don't) quote.Yet, we've had several days with around 300 deaths, 1/3 of the deaths in the pre vaccine days.
Omicron can't be both harmless and kill hundreds of people. Somebody is lying again.
Does compulsory not mean that you to have it?If it becomes compulsory here, I definitely won't get it.
More non-reading the whole post, more misquotes and invention from him. You're sick, fellah.You said "isn't very bad" which suggests it's almost harmless, and your whole point was about not bothering to get the vaccine now.
Do you believe that rule by decree is 'protecting it's subjects'?The primary duty of a government is to protect its citizens.
Pray tell, how do think that would be enforceable?Does compulsory not mean that you to have it?
That isn't enforceable...Simple. Check if someone has been vaccinated by checking their NHS records, if they haven't then they will suffer the consequences.
