Despair not, we are right on track, and black hole is the right title for this phenomenally mental number of Graham=
http://www.youtube.com/watch?v=XTeJ64KD5cg
But who knows, exactly how many atoms there are in our universe, I believe if every atom was joined with a straight line to all other atoms, as in my example of town centres connected with each other via direct motorway links, then I thin, it may exceed Graham's number, may be may be not, who knows? but sure you can work it out mathematically and the number won't be infinity. Since there must be exact number of atoms at any given moment in universe
There are two formulas to achieve this number, there may be more methods, but two i worked out are thus;
Let us take my example of 32 towns (represents 32 atoms) and each of these towns are linked to all other towns by a direct Motorway so I asked how many motorways would be needed to interconnect all towns with a direct route, the answer was 496, here is how it was arrived at using two different methods
Method one
1.Square the number of towns (or atoms in the universe) 32x32=1024
2. Minus the original number form the above squared number, so 1024-32 =992
3. Divide the above number by 2 , so 992/2 =496
2nd method
1. take the first number, and Minus 1 from it , so 32-1 =31
2. Multiply the above answer by half of above answer so = 31 x 15.5=480.5
3. Add the halved number (15.5 ) to above number to get the exact answer so 480.5+15.5 = 496
Another interesting thing I worked out but possibly only applies to tens
so for a 10 atoms total number of independent connections would be 45
for 100 =4950 (Note we have a 9 & a 0 )
for 1000=499500 (Note this has an extra 9 and an extra zero at the end!
so for 10,000 =49,995,000
this from this pattern or behaviour, we could work out what it would be for numbers exceeding trillions as most normal calculators won't handle large numbers, unless you have a scientific calculator
so if i may carry on a bit
100,000 =4,999,950,000 ( note it has same number of 9s and same number of zeros with 5 in the middle and 4 at the beginning.)
1,000,000=499,999,500,000 (5x9s & 5x0s)
10,000,000 =49,999,995,000,000
100,000,000 = 4,999,999,950,000,000
1,000,000,000=4,999,999,999,950,000,000,000
So I am not sure if this pattern continues or starts to expand, but notice the number of 9s and 0s at the end is 1 less than the number of zeros in front of the 1 on the left.
so we may jump to this figure now just to see;
1,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000 (1 with 60 zeros) or ( 1x10 to power of 59)
The answer would be 4,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,999,995,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000. (59x 9s and 59x0 )
So yes, this may not be as big a number as Graham's Number as I have hardly managed to fill this screen so whereas graham's number won't fit inside our Universe!
