definition of divide is to cut it (any number or anything for that matter) into any further number of parts, where it is possible. ( FOR EXAMPLE YOU CANNOT CUT OR DIVIDE AN ATOM INTO two further parts ) (sorry for the caps)
1 divide by 1 equals 1
That's about two and a quarter inches on my screen. It would be longer if I made the font larger.
So, if your answer is correct, that is if it is correct, how long does it then take to divide 2 by 1?
Do you really really really wanted to know the truth, No one has managed to date divide anything by 1 so far, so God knows how the heck you got your answer. You must be God's best friend!
True Definition of Division is cutting anything or any number by any other number apart from 1, you cannot divide by 1, you try and cut 1 into 1 or 2 into 1 and you will fail. So in other words any number you divide by 1 will be the same, so you don't even try, And yet you can divide anything by zero, and annihilate the thing into non-existent. However, the definition is somewhat confusing as well, since if you tried dividing 2 by 2, you get 1, here the division actually works the opposite, instead of cutting you are patching two things into 1! however, if you divide 2 by 3, you are cutting it! so in other words, if you divide any number by itself you are patching it into 1.
So the answer would be zero time. Since you cannot cut anything by 1, so you would not even attempt and so it should not take any time.
You can, as I understand it they're made up of protons, neutrons and electrons. Protons and neutrons can be divided into quarks, I don't know what comes after that.
Its like you cannot clean a clean window, can you, you will just waste your energy!
