I have removed an old extractor (installed by previous owner) to be replaced with a new one.
The old one did not have a plug but the cable was attached to a live cable behind the wall using a connector block.
Yours is not a unique situation, I have come across many wired up like that including my own hood wired up like it by my kitchen fitter in 1992.
My handyman says the new extractor fan has to plug into a plug socket?
Only portable appliances are usually plugged in, like washing machines, Microwave ovens., gas cookers with spark ignition, I have not yet come across a cooker hood requiring a plug and socket but I have seen some where it is connected to a fused spur, I guess it makes one's life easier for next time you or someone needs to take it down, simply unplug it. just makes it convenient rather than from a safety point of view. You could be wire it into a fused spur nearby, but this would mean you will have to remove your tiles and chase wall and run a conduit and then feed wire through it and connect it directly into the fused spur.
Does it? Could I not just cut the plug off the new extractor and connect it in the same way as the old one? Should I first find out if there is an isolator switch? and should it be a certain distance from the extractor fan.
I don't see any problem with this method, as it has been used in your place, I have seen it used in many different places, but as majority here insist that it should be wired into a box, I will therefore go along with them, since doing it this way covers all angles. (but just that I didn't see it can be a problem, but have to go along what the majority says here)
I recently had an electrician sign off on everything prior to rental so I dont know why I should need to install a plug socket just because the new extractor has a plug on it?
Chances are he didn't see it how it was connected, as it was out of sight and out of anyone's reach unless the hood was taken down, and may be he would have commented on it and asked you to get it wired into a fused spur with an isolation switch.
Can anyone confirm?
All of the kitchen wiring is about 15 years old. The rest of the house wiring is much older.
So whilst you are at it, get a box installed and wire it up in the box for added peace of mind,knowing that it would meet all required standards. If you really wanted to do it more properly, then you can get ABS boxes with cable glands that can provide cord grip and a terminal block fitted inside with IP65 protection rather than using an ordinary electrical box that has knock outs and simple round gromets that does not provide cable grip, as cables can get pulled out if stressed, and particularly if earth wire comes away lose, it could become dangerous if there was an earth fault on the hood (live making contact with metal hood) also make sure no wires can get trapped behind the hood when wiring, so where your box will need fitting depends on where the cable is exiting from the new hood, and work the best route and position for the box.
