A 'consensus' may be asking a little too much. Most people seem agreed that the best approach is to simply have the two chimes wired in parallel and the two push buttons wired in parallel, with a single transformer to power both. That would probably preclude your idea of using "chime and transformer in one" since, as has been suggested, even if you disconnected one of the transformers, the other one might well not be man enough to reliably/satisfactorily operate two chimes - you would then have to find an 'external' transformer that was man enough to do that.That's correct. I am after two bells to operate from a single push button. Do we have a consensus on how this should be wired?
Yes, I knew that (but forgot!), so you can forget what I wrote about two buttons - but, otherwise, what I says stands.I've already lost the idea of transformer and chime in 1 but to be clear, I will only have 1 push button. 2 chimes operated by 1 push button.
My sincere apologies!He wants two BELLS!
That would be the usual method, so all of the connections are inside one of the chimes.Do I take bell wire from transformer to chime #1 and from chime #1 take a bell wire to push button and another bell wire from chime#1 to chime#2?
I'll second that - I had a 10m run of bell wire and the bell just clicked once because of the volts drop.Volt drop can be an issue, depending on the length of the wiring runs
The standard bell wire is
1/0.6mm copper 22AWG (23SWG)
The maximum is 1.8amp.
You'll probably need to use something like 0.75mm² twin cable. And that will include the wires to the bell push.
