But then we wouldn't of had the drill test. --- Which I won by the way.Could of hired one for not much more than you've spent on drill bits.
I think you would of got on much better if you first used a 3 or 4mm CYL-9
Perhaps so, but that would have added more expense to the job.But then we wouldn't of had the drill test. --- Which I won by the way.
Like cats then! LolAsk your neighbour for an sds.
My makita sds is shared between the whole neighbourhood...
Massive. Like night and day.So what is the difference between an sds drill on rotation and hammer and a non sds drill set to hammer.
I see - thank you.Massive. Like night and day.
One relies on a hit-and-miss type hammer where the tool is vibrating. SDS uses a percussion strike at the base of the bit and will punch through anything.
A SDS drill will continue to drill a hole through a brick, even when the hardened tip is missing.I see - thank you.
Thanks. Didn't know that's how a SDS drill worked.Massive. Like night and day.
There is no comparison really. SDS is brutal in comparison and effortless.Thanks. Didn't know that's how a SDS drill worked.
A quick 'Google' tells me that SDS stands for 'Slotted Drive Shaft' and that the drill bit moves forwards and backwards within the chuck. A 'hammer drill' moves the chuck containing the drill bit backwards and forwards
Makes me think that with lots of use an ordinary 'hammer drill' will 'wear' and ultimately, the 'hammer action' will lose its efficacy?
Dave
bits of flint and steel reinforcingI have no idea what these concrete lintels are made out of, but boy oh boy is it REALLY HARD stuff!!
The material within is dense because it is vibrated to rid the conc of air.I have no idea what these concrete lintels are made out of, but boy oh boy is it REALLY HARD stuff!!
