I agree with your thinking which is from a different angle of course, and you are right, it is like saying is the glass half empty or half full, so it depends how one looks at phases with respect to power, voltage, and a 0 volt reference or Neutral . or between the top peak and the bottom peak, I of course was looking at it from both the top and the bottom peak at the same time, not against a zero reference.
But thanks for taking part in this discussion and thanks to PBC as well for confirming that 90 degree phase shift does not arise in the power lines of a split power supplies, which may be called 2 phase or whatever one chooses to call it, there is no difference in time for the power curve going up and a power curve going down, both occur at the same time with respect to mid point or zero or neutral point, the 90 degree phase difference does not occur as in Busbar's post in that particular scenario.
The confusion lies of course how one looks at it, it is relative to observing point, like when two planes flying in a same path closing on each other, both pilots each pilot accuses the other heading towards him, both are wrong and both are right, all at the same time. (this funny logic!!!!!)
