Hello all,
I just had my garden room certificated by an electrician. He said the earth reading is high but it passed but he advised to install an earth rod, I did ask before the installation if an earth rod would be needed but was told the house earth is enough I should have insisted on an extra earth rod but you try and leave it to the professionals.
I believe I have a TT System, got live and neutral coming in and earth going out to an earth rod on the house.
The consumer unit is on an internal wall and running a new earth cable is somewhat not possible. However I already have a 10mm earth for water pipe bonding on an outside wall, that is connected straight to the consumer unit. So can I just run another 10mm from that pipe to an earth rod or do I have to run a new earth cable to the consumer unit.
Thank you.
Thank you.
