Indeed. I think this has to be one of the most extreme examples I've seen of 'tangential discussions', even in this forum!I never realised earth sleeving was so complex...
Kind Regards, John
So - not so much confirmation as agreement with your view.Thanks for confirming - that is, of course, what I've been suggesting all along.
Fair enough.So - not so much confirmation as agreement with your view.
Indeed, provided that the pressure (whether atmospheric or otherwise) is the same in both cases. The question we are debating is that of the conditions required to cool the air (hence increasing density) without there being a corresponding reduction in pressure.The fact is that: Cool air contains more oxygen than the same volume of hot air. This is true whether the air is compressed or not.
I thouigh that I more-or-less had, but I'll see if I can do better.Can you please find an authoritative article which states that the main or primary purpose of an intercooler is to prevent detonation rather than increase the density?
Yes.The one with the intercooler is cooling AND collapsing the air, and in doing so, if it were a fixed volume, would be creating a lower pressure. But it's not a fixed volume, though the air pressure is still trying to collapse, but up-stream of said collapsing air pocket is the 'charger.
Surely it will continue charging until 2atmos is reached.Now though, the charger, in one engine is increasing air pressure from say 1atms to 2 atmos. The other is increasing air pressure from 1atms to 1.9atms,
Why/how will it flow more at a reduced pressure?so it can flow more.
If that were the case then logically surely it would flow better at 1.8 or even 1.0atmos.And that extra flow is the name of the game.
As above, because the turbo is still charging.Indeed, provided that the pressure (whether atmospheric or otherwise) is the same in both cases. The question we are debating is that of the conditions required to cool the air (hence increasing density) without there being a corresponding reduction in pressure.
I'm sorry if I have missed a link.I thouigh that I more-or-less had, but I'll see if I can do better.
Yes.
Obviously the flow will be greater at higher pressure and be even better with increased oxygen because of lower temperature and increased density.
The fact is that:
Air (and nearly everything else) contracts when it is cooled.I am not sure if I can bring myself to agree with your facts without mentioning under what conditions, as I explained earlier, if you trap some air in a canister and seal it, then no matter whether the temperature of the whole can is hot or cold, the density of air trapped within that can will be constant, its density won't change when it is any colder, because it will still contain same number of molecules of air, unless you want to tell me that when it gets very very cold then all the atoms and molecules of air condense and fall to the bottom of the can and leaving vacuum on top, then one might see some light in your statement of fact.To do this we will need a glass jar and trap some air and put it in a deep freezer to see if the air inside condenses to liquid. Pressure regulating valve ensures targeted pressure is available at the inlet manifold, within a given RPM range, the density of air should remain constant as well since to maintain pressure steady more air is pumped in, that means any tendency of density to lower is curtailed by more mass of air arriving thus maintaining steady density.
I thought I was the only one NOT saying that.2nd point I made and you negated it was that in a turbo charged car, turbo compressor is pushing air into the manifold all the time within a given engine speed range, so any loss of pressure due to cooling by an intercooler gets replenished by more air forced in to compensate, loss of pressure, so a steady pressure is mintained, and so like in my example of a closed lid can, if you take two cans and in one you put normal atmospehric pressure (air) and in another you put 2x atm, now you got two jars where one with higher pressure has more density.
Yes, but if the air is cooler it will contain more oxygen by volume.As for dynamics of a turbo charging, it is no different to a voltage regulator, a voltage regulator regulates precise voltage irrespective of temperature varaition and load, its job is to supply current within its designed range of operation, same way a turbo charging system will maintain a certain amount of pressure at the inlet manifold irrespective of cooling or not cooling, because pressure is regulated by a pressure regulating valve, known as a dump valve, where a minimum pressure is maintained within a certain RPM range,
That's where you are going wrong, then; are you thinking of mass again?So no matter how much cooling is being done to the incoming compressed air, if it cools down too much, the pressure will drop, if pressure drops then more air will be forced or pumped in to maintain pressure, so when pressure is kept constant, then density should not change, even through cooling by an intercooler,
Eh, that's surely untrue as a generalisation? Gas in a sealed container will always fill that container, regardless of anything (provided it remains as gas), and therefore cannot 'contract' or 'expand' (i.e. change in volume).Air (and nearly everything else) contracts when it is cooled.
Ok. that's a fair comment but if sufficient cooling and contraction the container will collapse.That's not right ELI, I'm sorry you need to re-think your mental model. The air will only contract if the sealed rigid container lets it. The pressure will drop, yes - but contraction only follows if the container collapses. If it's a balloon, the balloon will shrink and expand accordingly such that the pressures inside and out match.
