It's a bit of a misnomer:
Hot wire sensor (MAF)[edit]
If
air density increases due to pressure increase or temperature drop, but the air volume remains constant, the denser air will remove more heat from the wire indicating a higher mass airflow. Unlike the vane meter's paddle sensing element, the hot wire responds directly to air density. This sensor's capabilities are well suited to support the gasoline combustion process which fundamentally responds to air mass, not air volume. (See
stoichiometry.)
This sensor sometimes employs a mixture screw, but this screw is fully electronic and uses a variable resistor (potentiometer) instead of an air bypass screw. The screw needs more turns to achieve the desired results. A hot wire burn-off cleaning circuit is employed on some of these sensors. A burn-off relay applies a high current through the platinum hot wire after the vehicle is turned off for a second or so, thereby burning or vaporizing any contaminants that have stuck to the platinum hot wire element.
https://en.wikipedia.org/wiki/Mass_flow_sensor
excellent article, reinforces my own thoughts on density must also increase with pressure, but depending on how this pressure is being created, here the volume remains constant (duct work and intercooler space volume) but pressure is being created by turbo pumping or forcing more air (more mass) into the system, but of course not in a sealed jar (static volume) where pressure can also increase by increasing temperature since number of atoms (mass) remains unchanged, i.e. no further topping up of atoms (mass)
So yes we are all right, it depends on lots of factors, and conditions, and changing one factor or conditions also then influences another, and this means constantly varying parameters.
I am also beginning to understand that how lowering temperature can result in increase in density, but only under certain given conditions, and certainly not under all parameters.
A turbo systems is complex, it could be static for a few seconds as well as fully dynamic, or in between depending on the amount of throttle opening, how rapid the cooling occurs, what pressure is the turbo pushing mass of fresh air into the system, how hot it is to start with, are there any turbulence within the duct work and within the intercooler.
so yes the bottom line is there are far more complex goings on than a simple Boyle's law, I am sure intercooler must help in many ways to prevent pre-ignition that can cause detonation which is also known as pinking, or knocking, and help densify air density.
Talking of pinking, in the mid 70s, I use to run my car on heating fuel (paraffin) and it used to pink like hell, but at half the cost of normal regular petrol, it saved me a few bob to spend down my local, to reduce the pinking I had to ****** static ignition timing from a knurled knob on its distributor and disconnect vacuum advance pipe, fun days I called them.
so yes we all now agree that intercooler does both, it increases the air density by cooling compressed air, and lowers the temperature to prevent pre-ignition.
that leaves one other thing we have not talked about and that is What does Amal valve do? I like to hear from you and not google it.
Not 10 pages yet come on get your pen out!
