sterose said:You dont earth steel shelves and towel rails because there is NO path to earth (assuming is is fixed to brick or wood) unless it is connected to something with a path to earth.
You do earth radiators though because they are generally somewhere conencted to earth, usually at a boiler (because the metal of the boiler must be earthed).
Water does conduct electricity but has a high resistance.
This means that, without me knowing the exact resistance, a current that is less than the fuse rating can flow through you.
Like i said, if the resistance of water means that a current of 39 amps flows from your shower into you, but the shower fuse rating is 40amps, the fuse will never blow because it is still below its rating.
However, 39amps can damage you if not set you on fire.
Please ask further if you dont understand.
As a final point, a totally earth free environment is the safest place to be, eg. you could touch the 240volts mains and not be electrocuted. BUT no place in a house is totally earth free, eg. there is always something that will conduct electricity. The problem in bathrooms is that there is plenty of water and metal, and electricity if you have a shower. If an electric appliance fails somehow, it is the most likely place for you to come into contact with the faulty appliance AND be touching something with a path to earth.
Also, save yourselves time by simply learning about this instead of arguing with me. I know im right. Because when I argue, i always know im right.
sterose said:I'm sorry, ban-all-sheds for my apparent tone of voice, I was just stressed with an unrelated issue.
I accept your explaination for the shower example, I have not analysed the actual resistance for it. I was just making an eggagerated example of what could happen of the current was just below the rating of the fuse.
I personally don't know the value at which someone can be killed. But I once heard that a sustained current of only 1/millionth of an amp is enough to kill in certain circumstances (please correct me...)
"But even so it doesn't look, at first glance, as if the resistance of any reasonable length of water in a plastic pipe would be low enough to allow a hazardous current to flow through someone - your radiator would be, for practical purposes, earth-free, and therefore safer than one with a bonding cable attached."
Yes, i have considered this myself, but as i say i dont make the rules.
Just for a moment, lest assume your radator, that is practically "earth-free", becomes live due to an electrical fault - and lets say that the appiance in question is 13 amps (maybe a heater)- there will be a *very* small amount of current flowing through the radiator to earth, not enough to burn the fuse in the portable heater.
Next lets assume, for some (unlikely) reason, you happen to touch something that IS earthed, maybe a tap, with a very low resistance, but still not enough to let the fuse burn out. It will then proceed to inflict a current on you without the fuse burning out.
The effects of that current are, for this explaination, irrelevant.
The point is that if the radiator was earthed in the first place, the >13amp current would have earthed and burned the fuse out. Saving you the unzzzzsavoury (laugh) experience of being electrocuted, and also avoiding the possibility of fire because of the heat that may, or may not, have been produced by the faulty appliance earthing out.
sterose said:Drole, Jim. Very drole.
The radiator is not an isolated metal item. It is a large fixed item. There is an infinitely greater chance of me toughing a radiator and getting electrocuted than there is with a teaspoon.
After all, i find it laughable that someone might not notice a live electric cable connected to a teaspoon!
I also suggest anyone with further issues reads Jim's suggestion - http://www.iee.org/Publish/WireRegs/EarthingPlasticPipes.pdf
I'm not exactly sure what you are saying, but i think what you are syaing is that the pipes leading up to the radiator are earthed but the actual radiator itself isnt.
I think you can get radiator earthing straps, but i would think that just earthing the pipes would do. Thats what I did.
Basically, what people should do is get a length of cable, and earth straps, and if its metal... earth it.
No worries - if I had a pound for every time I'd done something like that, I'd be able to afford to employ an electriciansterose said:I'm sorry, ban-all-sheds for my apparent tone of voice, I was just stressed with an unrelated issue.
I'd be very surprised if 1 microamp was ever enough to kill. Does anybody know what current flows through your body when you use a neon tester?sterose said:.. I once heard that a sustained current of only 1/millionth of an amp is enough to kill in certain circumstances (please correct me...)
Indeed not - but it seems from the document on the IEE website, that you don't have to earth radiators that are fed by plastic pipes - in fact you shouldn't:sterose said:"But even so it doesn't look, at first glance, as if the resistance of any reasonable length of water in a plastic pipe would be low enough to allow a hazardous current to flow through someone - your radiator would be, for practical purposes, earth-free, and therefore safer than one with a bonding cable attached."
You don't have to connect an earth directly to the radiator, but if you've used PTFE tape on the joints it might be a good idea. Certainly wouldn't do any harm.climberjim said:I have radiators with metal pipework. Currently the pipework is earthed but there is no additional earth strap between the radiators themselves and the pipes. Does this need to be the case or can I just rely on the pipe fittings making the earth connection.
Well, yes and no.bonus said:...I am in the middle of some bathroom projects at present. My house is around 7 years old. I have recently moved from a house that is two roads away and it is of the same age.
After, stumbling across this thread, it has just ocured to me that none of the pipes in my bathroom and shower room are earthed. In fact, I've had a look around the house and no pipes whatsoever are earthed.
Am I living dangerously or is there another way of doing this
So do we all... If you're in doubt about your ability to install a shower, get a professional in.I have an electric shower which I am replacing this week. I have had to endure an electric shower every day since moving in earlier this year. Two blew up on me when I was a kid, I hope I haven't inherited my Dad's DIY skills
