Low load, on a high amp circuit (Ed.)
24 Dec 2024
i plan to run this with about a 4amp load would this be fine on a 16amp commando if im only drawing around 4 amps from the ups eaton say a 32 amp recommended but itll never see more than a 4amp load so would it be fine on a 16amp commando?
You seem to be confusing various numbers.
Why do you want to use a commando and not a normal 13A socket with a fuse in the plug?
