I posted this on the plumbing / heating section but others suggested this was a better place for it....
I currently have an issue with my Economy 7 storage heating system and water and would really appreciate your help / ideas. I've searched the forums and can't find an obvious solution. Apologies in advance however I am not DIY or electrics savvy (I feel a sense of achievement just wiring a plug ! ).
My issue is:
For the last few days, both my storage heater and my water heating do not function on the Economy 7 cheaper rates ie overnight. Therefore if i leave the normal plug type switches on for the timed Economy 7 operation overnight, neither is there any heat from the storage heater, nor any hot water, in the morning. They do, however, work using the manual booster switches - which is therefore my only method of heating the water tank and the storage heater. This will be costing me substantially more as well as the fact that I seem to run out of hot water more quickly even if the manual booster switch has been left on for a long time.
My set up:
2 bed flat - built 13 years ago (I've been here for most of them). No replacing, altering or issues of/with heating or water tank set up.
Dimplex storage heater in lounge. Connected by 2 wires to 2 separate switches - 1 is manual booster switch that allows it to be switched on immediately (that works fine) - and 1 switch that I would leave on permanently and previously would mean the storage heater heated overnight and released the heat during the day - this now doesn't happen.
Water tank with 2 wires connected to 2 switches - both the same operation as above. Again manual booster works and heats water - the permanent switch being on now doesn't result in water heating up on its own.
I cannot see a timer or teleswitch dial or anything similar anywhere in the flat - so am assuming it must be happening in the meter automatically?
Advice please:
Please could anyone advise me on what the most likely issue is?
Secondly is there likely to be anything simple I could or should do to verify the above bearing in mind I'm not an expert in any shape or form.
If the issue is likely to be complicated - or a complex investigation needed to assess the problem, then I do have an electrician that would come round for a fee - I just would really appreciate a bit of guidance on what he should do before I pay for it, as he has not had any Economy 7 experience - on the phone he said sounded like my whole element in the tank would need replacing which could cost close to a grand!!! Is this really a likely scenario / cost? Scares me as winter is coming so maybe I am for forced to spend that much even though I will struggle to afford it.
Thanks in advance.
Pics attached for info:
Read more: //www.diynot.com/forums/plumbi...ot-heating-up-overnight.340452/#ixzz29Gh46UXt
My issue is:
My set up:
Advice please:
Thanks in advance.
