- Joined
- 27 Jan 2008
- Messages
- 25,785
- Reaction score
- 3,060
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
At one time we had two meters one for lights and one for other power, the power for lights was cheaper and it was illegal to use other power items from the lights supply, and people were taken to court for using light power for other things, however this caused safety problems and well before I was born the duel supply idea was abandoned.
So I think it is unlikely that duel supplies will return.
As to economy 7 this is a tariff not a wiring system, as already said there are many ways to use the power, however for the electric vehicle there is a problem off-peak hours might be 11pm to 6am, 12 midnight to 7am, 1am to 8am or even 1.30am until 8.30am it depends on supplier it is not fixed. Now if you arrive home at 11 pm and the 7 hours start at 11 pm then that is great, by 6 am most the charging will be complete and it is going to just finish off using just a small amount of power at peak rate.
If however the off peak starts at 1:30 am and you plug in the vehicle at 6 pm most of the charging will use electric at peak rate which light use charging will be complete by 1:30 am however with a heavy use if you delay charge until 1:30 am it may not be complete in the morning when you want the vehicle.
With a special charger and vehicle set up it could be programmed to alter the charge rate to match the economy 7 supply, but as far as I know that technology does not exist, and with solar panels it is possible it never will as in the future the idea of using off peak power to even out the supply may not an advantage any more for the supplier.
It the vehicle supply only came though some sort of smart meter then the energy supplier could offer a special rate for vehicle charging where they can remotely switch the supply on and off to match demand, however this is something for the future. You would not want whole supply switched by energy provider only the supply to the electric vehicle.
I can see in the future special rates being on offer for the electric vehicle so they can be auto turned off at peak times. And with the new breed electric car with built in generator to extend range and allow recharging where there is not charging point it could be the way forward.
For some users with a standard daily usage they may know if charging started at time when economy 7 starts they will have enough charge to recharge within time. However with economy 7 the on peak power costs more, so unless one can ensure the off peak only is used then not really a good idea. Likely having the supplier switch power on and off is the best method to ensure you don't use on peak power.
As to what will happen if you switch off the charger with it still connected to the car I don't know, some chargers actually start to discharge batteries if left connected to batteries with no power to charger.
