- Joined
- 11 Jan 2004
- Messages
- 43,566
- Reaction score
- 2,799
- Country
Is installing to MIs still in the big book?I doubt it but overheated wire in a 3KW oven doesn't happen if protected according to MI's
I thought it had been struck out.
Still there, but MI's now only "have to be taken into account", whereas previously there was a requirement to 'obey' themIs installing to MIs still in the big book? ... I thought it had been struck out.
Sure, manufacturers can write whatever they like, although I suspect that if some 'authority' discovered that a manufacturer had written something that was positively dangerous, they would probably have something to say about itThere is nothing to stop the manufacturer stating 'this component must be protected by...'.
Let me try and make another comparison, If you purchase a jack for lifting cars and it has a 1 ton lifting capacity and it collapses, would you expect it to be repaired/replaced?Sure, manufacturers can write whatever they like, although I suspect that if some 'authority' discovered that a manufacturer had written something that was positively dangerous, they would probably have something to say about it
However the point is that, although it did in the past, BS7671 no longer 'requires one to 'comply' with' MIs.
Kind Regards, John
Well if you are lifting 1 ton or less by proper means I would say yesLet me try and make another comparison, If you purchase a jack for lifting cars and it has a 1 ton lifting capacity and it collapses, would you expect it to be repaired/replaced?
So you are happy to accept the manufacturers intructions to limit the load to 1 Ton in order to prevent damage to hydraulic seals and linkages etc but you are happy to ignore the manufacturers instructions to limit the current to 3A (example) with a fuse etc and I assume you would expect them to repair when damage is caused by the ommission?Well if you are lifting 1 ton or less by proper means I would say yes
Please explainApples and oranges.
You are comparing things which are different and assuming the electrical device can or will be damaged if the 3A fuse is not fitted.Please explain
Having been in the situation on more than one ocassion where an overload of an incorrecly installed circuit has occurred, I think it's only fair I can make such assumptions. I mentioned in a post fairly recently an oven in such a condition which the manufacturers maintenance agent very quickly established the cause and refused repair, in my opinion very justly.You are comparing things which are different and assuming the electrical device can or will be damaged if the 3A fuse is not fitted.
They verywell may well do, on the other hand providing instructions to restrict the lift to 1 Ton is adequate as the operator has control on what they are lifting whereas the operator of an oven has no such control of the current it can draw, other than fiting the correct OCPD as instructed by the manufacturer.Why don't the manufacturers of your jack make it impossible to put more than 1 ton on it?
There is some truth in that, it can easily be achieved by selecting the correct fuse in the plug for example.The point is that anyone who manufactures and sells a piece of mains driven equipment is legally obliged that if that equipment fails internally it should not create damage outside itself that was preventable. Setting a house on fire because they wanted to save money on a fuse is not acceptable.
any requirement/recommendation is to be added by the next stage of manufacturing which happens to be the installer or electrician in accordance with the paperwork supplied unless their risk assessment is such that they think the information supplied can be ignored, in which case they are obliged to accept responsibility for failures....legally obliged that if that equipment fails internally it should not create damage outside itself that was preventable. Setting a house on fire because they wanted to save money on a fuse is not acceptable.
Specifications and "MIs" are surely two totally different issues, aren't they?Let me try and make another comparison, If you purchase a jack for lifting cars and it has a 1 ton lifting capacity and it collapses, would you expect it to be repaired/replaced?
