What thread was that please.An example which has immediately occurred in another thread is that we no longer need run a CPC to all points where class 2 items are fitted.
I think he may of been thinking of my comment in my post #19 in THIS thread, when I wrote ...What thread was that please.
Who knows - it's seems to have become a purely individual personal judgement .... it's possible that the judgement of some individuals might be that not having a CPC at a 'particular point' "may result in a danger" if a Class I item is subsequently installed at that 'point', and therefore that to not have a CPC would be "non-compliant" - but, as you imply, if they do not take that view, then not having a CPU to the 'point' is presumable NOT "non-compliant"! ..... In my opinion, a total mess, created by a tiny number of new words!
There's a good argument that replacing a light fitting is a modification, and if you argue that something will be dangerous IF someone modifies the system in teh future then that's a very large can of worms. On the other hand, I'd be "a tad annoyed" if I wanted to fit a Class I light fitting and found that some **** had omitted a CPC... it's possible that the judgement of some individuals might be that not having a CPC at a 'particular point' "may result in a danger" if a Class I item is subsequently installed at that 'point', and therefore that to not have a CPC would be "non-compliant"
In the context that had me start this thread, the property in question is a rental property. There is no legal requirement YET in England for a periodic inspection, but there is in Scotland and I believe it's on it's way in England when the legislation works it's way through. Now I think we all agree that but for 421.1.201, we'd be quite happy with a plastic cased CU that was made to the appropriate standards, was installed properly, and was not damaged. But, having even a C3 on the EICR is undesirable as that opens the door to certain types of tenant to take advantage.People are willing to accept that things should be updated - far too susceptible at times, it would seem.
Watch this week's Panorama., having even a C3 on the EICR is undesirable as that opens the door to certain types of tenant to take advantage.
Some will simply question it and need some explanation. But some will try to profit from it - yes some people will do all sorts of things to scam a bit of profit (seen it first hand)
Yes, we discussed that many times before, and it is obviously would be ridiculous (and impossible) to try to anticipate (and attempt to mitigate the possible consequences of) all the stupid things that people might do to an electrical installation in the future.There's a good argument that replacing a light fitting is a modification, and if you argue that something will be dangerous IF someone modifies the system in teh future then that's a very large can of worms. On the other hand, I'd be "a tad annoyed" if I wanted to fit a Class I light fitting and found that some **** had omitted a CPC
I confess that I haven't myself looked recently, but I was going by what Simon wrote .......but ... as I mentioned, is 'non-comformity' or 'non-compliance' the criterion for a C3? ... Is it not instead simply that 'something' is not to the current regulations?
[I assume that, in "18th-speak", he meant "non-conformity" rather than "non-compliance" ]..... Go and read 653.2, item 4, where it says : "any non-compliance with the requirements of BS7671 which may give rise to danger". So it is clear that non-compliance isn't sufficient reason for reporting ...
Magnesium
No-one is saying that one can't - 'ferrous metal' is merely given in BS7671 as an example of a material that would be deemed to be 'non-combustible'.Why not make a metallic ( and hence fire proof ) CU out of a metal other than steel ?
... and, I image, a lot more expensive. Is it not also less "non-combustible" than steel?Magnesium is lighter and ( when correctly used ) stronger than steel ( weight for weight ).
Who do you mean by they? The ones distinguishing between cupboards and elsewhere?If that's true (I don't have the regs to hand) then, given the current definitions, they appear to be saying that a non-conformity doesn't need to be reported (in an EICR) if it isn't a non-compliance, don't they?
Why not make one out of non-combustible plastic?Why not make a metallic ( and hence fire proof ) CU out of a metal other than steel ?
