Oh, he provided caps? Maybe all will be OK once carpeted?
https://photos.app.goo.gl/zfTzAxAE8CFXGf6c7
A slightly separate question: The other thing I'm now slightly anxious about is the holes in the joist where the wires are fed through - just been reading about the areas where building regs say you can drill - between 0.25 and 0.4 of the length of the joist? How does someone know the length of the joist i.e. if they span a single (3m) room or the whole of the floor to calculate where they are able to drill as this would affect where this section was located? They look sensibly sized for the wires.
If I hadn't been so involved in the process he'd have put the carpet back himself and I'd probably never have known or been anxious about any of these things - ignorance is bliss etc etc.
I missed that photo. Yeah, that looks tricky! But so does that copper pipe so near the floor - all my pipes run below the joists, so you'd have to use a very big saw to cut through one.
Also, no lagging on the pipe - or is that upstairs?
Do you mean below below?all my pipes run below the joists,
it is central in terms of the height of the joist (which look like 8x2s). The holes are fairly small - I think 1inch diameter. I feel a little reassured from what I've read elsewhere that this will likely not cause any problems.
That is the method I was trying to describe as one that I have occasionally used myself.Yes, not nearly as bad I had imagined. I must confess I have never heard of that method before.
Can you see this?
This shows one that's been put back in (this split) and one that's been left off (where I was waiting for the plumber to come to check it). Sorry when I said circular saw I meant an attachment for a drill that cuts out a circle with a hole in the centre.
It's not that much of a disaster - a common method for chipboard floors, but saves a lot of time on floorboards too. You'd insert a batten through the hole and affix it to the surrounding area and screw the centre part back in. It just looks like they were careless and split the board. It should be flush though.
