Hi guys
I'm having a new bathroom fitted, I have a new 9.5kw shower, my plumber is a former electrician and he says my existing cable is 6mm, he says this is ok to use with a 45A rcbo. However he can't fit it apparently as it needs to be done by someone who can do household work. I've had an electrician come to look at it and he says he'll have to put bigger 10mm cable in as the 6mm isn't big enough. This is going to cause problems as the laminated floor will have to be taken up. Can you tell me who is correct?
Thanks Lisa
Thanks Lisa
