I can't see the point of estimating or calculating anything, especially approximately - this is a fault-finding exercise.bernardgreen said:One way to estimate the impedance of the cable...an approximate value for the impedance of the cable be calculated.
Again, assuming things is exactly the wrong thing to be doing here....This gave the voltage drop along the neutral of the cable to the socket without touching a live component. It could be assumed the volt drop along the live would be the same.
Coniferman said:It's not just colder because of the temperature of the incoming water being cooler in the morning?
tuttifruiti said:I've tried it on full and tried moving the temp to 10 but still not joy.
it's a 10.5kW rating.
