It will depend on the layout, where the various items are, pump, Valves, wiring centre etcI need to lay two further cables and they are for the purpose of the thermostats/programmers (2 zones). Can you please advise on the cable I need to use for this?
Which lies are you expecting him to tell?My job was to lay the ring main to first fix level and the electrician will be connecting in to CU and the services on the boiler end.
I'm sitting here totally unable to understand what kind of thought processes can possibly be going on inside the head of a man who finds he has to ask so many questions and yet does not regard his ignorance as a reason why he is not competent to carry out electrical design work.I need to lay two further cables and they are for the purpose of the thermostats/programmers (2 zones). Can you please advise on the cable I need to use for this?
Sorry for the incessant questions. I do have a "proper" electrician on board who has advised me and is inspecting the cables I have laid but he is away at the moment and I wanted to check that I am on the straight and narrow. He will be reviewing the installation (prior to boarding and plastering) and commissioning it.
I ask about the thermostat cable as he suggested wireless thermostats but I thought it would be better to have a wired system now that I have an opportunity.
They always are, aren't they.Sorry for the incessant questions. I do have a "proper" electrician on board who has advised me and is inspecting the cables I have laid but he is away at the moment
Reviewing and commissioning could indeed be inspection and testing.and I wanted to check that I am on the straight and narrow. He will be reviewing the installation (prior to boarding and plastering) and commissioning it.
Provision of a new circuit is notifiable work under building regulations. How will you do that?
The advantage of wireless stats is that you can move them around to the most suitable location, should you want/need to change it later.
The disadvantage is that they are, well, wireless - and wireless stuff can be flaky depending on the location/environment. Plus you have to feed them with new batteries from time to time.
Think carefully about all of this stuff, if you are starting from scratch. There are some systems that allow you to control heating and hot water from a smartphone. For example: Hive, Heatmiser, etc
Which boilers say that? I have never, ever seen that. The usual stipulation is a double pole switch with an isolation gap of 3mm minimum.Some boiler MIs state an unswitched 13A socket rather than an FCU as the preferred connection method.
