Thanks for the response.
It's a boiler running on Gas.
@flameport thanks for the info. I spoke with Heatrae Sadia and Worcester this morning and they confirmed the ampage you have posted above. Before I could arrive at the conclusion that a 3 amp boiler and 13 amp Immersion will be adequately served by my ring based on 2.5mm cable, the technical department at Heatrae Sadia suggested that the Immersion Heater must be on a separate radial circuit.
Does that check out with you guys?
On the 35KW boiler and large house. My house isn't small but given the variance in sizing, I am inclined to over size rather than under. Worecester also advised me that the 35 CDI boiler is fully modulated which means it can be throttled back.
I would welcome your thoughts on the above.
