fan hunt on glowworm 120ff
22 May 2014
West Lothian
The boiler works fine if either CH or HW or both are selected, but if both are switched off on the timer, the fan hunts.
Would I be correct to diagnose that the problem is with the air pressure switch,? The plastic air pipes look clear of debris and are in good order.
This is the DIY forum, you'll get help if you register and post this in the gas combustion section.
If you refer to the instructions there is a very useful fault finding guide which should cover this issue.
Piers
If both are switched off on the timer, should the fan run albeit badly.
