Fixing bolt to wall
Your interest is to have a tidy surface even if you blow half of the customer's brick away which might lead to collapse of his wall down the line
1) you've had explained to you multiple times that it is very easy to avoid blow out when using an SDS
2) for the job you did, most experienced builders would not have drilled into the cavity anyway, therefore avoiding any risk of blow out
3) a blown out brick will never, ever, cause a wall to collapse
4) circuit breakers will not stop you falling off your ladder if you get an electric shock.
