- Joined
- 27 Jan 2008
- Messages
- 24,901
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
With only 10 days not being used, why should Monday the 4th Jan be any worse to the 14 day and 28 day lock downs? ITV seem to think it's different does not "– Taking your vehicle for a “decent drive” several days before you need it." break lock down rules?
OK ITV not the only one, Halfords, Lancaster evening post, Telegraph etc all seem to have web page hits with a similar message.
However my wife's car just put battery on charge, showed 12 volt, which is typical of a car which has been left standing but the charge rate even at 3.8 amp which is rather low did not remain there for long, as with discharged lead acid batteries it takes time for them to recharge, and once at a point where will not start the car, we are looking at days to fully recharge.
I think the reports are old pages being raked up by the likes of Halfords who have been sending out emails to warn people and offer their services, posted on 20th November 2020 by Halfords, however today charging car batteries is not as easy as it was it seems. The problem is the car allows the battery to become 80% charged and only charges it on down hill stretches, when engine on over run, so to recharge battery can upset the computer control, I know with wife's Jaguar should charge battery from charge point under the bonnet, not the actually battery in the boot, and since the valve regulated lead acid or absorbed glass mat batteries have a very limited amount of acid in them, you need a smart charger that is designed not to over charge the battery. I use a cheap Lidi one, was around £14 but the ctek seems to be most well known, it seems odd, back in the 70's we had 4 amp chargers, then the battery charger started to get bigger and bigger, seeing even 20 domestic battery chargers, now back to small chargers again.
The big problem with a battery charger is if a cell goes short circuit, I lost a pair of batteries in the mobility scooter as a result, had I been aware I could have saved one, but it was left in the garage on charge with a charger designed to be left on 24/7 but no fail safe, so it over charged the remaining cells. Once the old Lidi charger has dropped to 0.8 amp rate it will not auto return to 3 or 3.8 amp rate, so unlikely to bake a battery if cell goes short circuit, ctek make many models of battery charger, the popular ones will return to max output if battery becomes discharged, great when using in a caravan or boat, not so good when leaving battery unattended.
Anyway idea of thread is to one bring it to the attention of people who have left their cars with boot light on over Christmas ect. And two maybe people can add to the tread saying how they look after modern lead acid batteries.
