My Ideal combi boiler has a maximum flow temperature of 55 degrees and a minimum flow temperature of 15 degrees set on it. Are these values ok? Thanks
That's what I thought - hence the question - they are the settings shown when I access the menu - seems oddThose temperatures sound more like DHW to me, although 15C isn't much use in either CH or DHW mode.
It's an Ideal Logic Combi 30. I accessed the settings through the Honeywell wireless.Which Ideal combi is it? I've not seen that minimum setting before.
I run my home on flow temperature rather than room thermostat.My Ideal combi boiler has a maximum flow temperature of 55 degrees and a minimum flow temperature of 15 degrees set on it. Are these values ok? Thanks
how can a thermostat interact with a boiler that does not support high modulation? A thermostat is on/off...its the boiler that does the workI have wondered many times about saving when gaining latent heat, but much depends on how the boiler is set up to start with. Both by manufacturer and installer.
I know my mothers did not have option for an electric modulating thermostat, latter Worcester Bosch do, but not OpenTherm which it seems means only controls one room, there may be one which links to TRV's but I have not seen one.
This means you have to decide either/or. Modulating thermostat, or linked to TRV's the control with TRV's will cause the boiler to modulate, but it will cycle in warmer weather without a wall thermostat, so the two need careful balanced, and I managed with mothers house, but failed with this house.
But boiler in this house does not modulate, so TRV control not so important. Mothers house once set, radiators always warm, very rare hot, or cold, just warm enough to maintain room temperature.
But is the saving enough to be worth swapping to a modulating thermostat? Having programmable TRV's yes, cost me £15 each in 2019, but paying £200 for new thermostat, that's half the years oil bill, not sure it will save enough?
Does this apply to combi boilers?1. Probably the most important feature from an efficiency standpoint is to ensure that the boiler runs for as much time as possible in condensing mode.
2. To run in condensing mode, the return water temperature as it reaches the boiler should be no more than 55 degrees.
3. You can work back from that to calculate what the flow temperature should be. This isn't a simple calculation as it depends on how the system (assuming radiators) was sized in the first place.
4. If the radiator system is modern, and was correctly sized originally, then the temperature drop across each radiator should be around 20 degrees, giving a flow temperature of 55 + 20 = 75 degrees.
If so, do we measure temperatures at the radiator pipes (flow and return?) Or at the boiler?
