My garage has a metal Wylex fuse box with two fuses. Wire fuses are 20A for the socket and 5A for the lighting. The house CU was replaced 8 years ago and the installed a 20A MCB for the feed.
Ideally I'd like to replace the metal fuse box with a CU and then run a radial circuit of sockets, 4x 2 way around two walls of the garage. No intention of going above 20A with loading.
Is replacement of this fuse box notifiable? (it's not the main house CU)
Should I change the house CU 20A MCB for something different?
Can I just keep the fuse box and wire in a radial circuit described above?
Many thanks,
d4ve
Many thanks,
d4ve
