Finally time for us to get back out in the gold ol' garden and finish last year's job, hopefully well in advance of the summer.
We need to lay flags/slabs in our "middle" section, behind the retaining wall we've built.
I've attached a diagram below that hopefully shows this. Key points:-
1. The retaining wall is 6 bricks / 600mm high.
2. Behind the retaining wall, there is 200mm wide clean gravel (up to 400mm high / the 4th brick high), with 200mm wide top soil for some plants (behind the top 200mm / 2 bricks).
3. Behind all of that is where we want to lay the flags (dashed pink line).
4. The dashed blue line is the original, sloping, ground level. Note that we did not excavate any earth below the blue line, OTHER THAN (a) the "clean gravel" area, (b) directly below the bottom brick and (c) 150mm either side of the bottom brick.
5. Behind the clean gravel/top soil, we have infilled with some of the clay soil that was excavated on site (green area). Each infill was compacted down at each 50mm depth of soil added.
6. We've levelled the infilled clay soil off to leave at least 200mm from the top of this soil to where we want to lay the flags (yellow area).
7. We are proposing infilling this final 200mm with:- 160-180mm Type 1 (compacted), and 20-40mm wet mix mortar bed (to hold the flags). As I say, the flags would run along the dashed pink line.
Q: Will 160-180mm Type 1 (yellow area) on top of the compacted soil (green area, max 200mm depth of compacted soil), be enough support for our flags, or should we we get rid of all of the infilled soil (green section) and infill that with type 1 instead?
Trying to save us a bit of money by using some of the existing soil we had on site (green area) but don't want to end up in the situation where flags break.
LINK TO ORIGINAL IMAGE:-
http://i61.tinypic.com/242sk7c.jpg
Some pics of area that we're referring to in garden:-
