r895neo: Thank you (as always); god knows where we'd be without your guidance (certainly not 3-4 weeks away from completion).
If we were going to do any haunching, where would you recommend we do it? At A, B, C or D on the pic below? Just C and D? The whole paving area falls/slopes downwards from A-D and from B-C i.e. from the top wall to the bottom wall.
Thank you - will ensure we do this for the remainder of the slabs. How much in circumference/diameter around the steps should we be using a wet mix/sbr/bond bridge technique?
Thank you once again - the slabs we laid last week that ultimately became "picture framed" were laid bone dry (on a wet mix) so will ensure they're laid damp from now on.
Thank you.
Are the following products ok for the pointing mix of 3:1 building sand / cement (laid semi-dry/moist)? Which is best - powder or liquid? Probably going to go with the brown as that's the instruction from the missus! If not, what product would be best / recommended?
http://www.jewson.co.uk/building-materials/chemicals/cement-colours/
What type/brand of plasticiser should be used for (a) bedding and (b) pointing?
No need to haunch really if laying on a wet mix. its worth a little haunch but nothing major.
You really want to lay your slabs near the steps on a wet mix or you risk them not bonding well. Using SBr or the bond bridge technique on paving expert will also help.
Picture framing can be avoided by making sure the slabs are a little damp and kept damp as laying proceeds. this stops them absorbing water and therefore cement. It more commonly a pointing problem though.
A moist mix will be usable for 3ish hours depending on conditions.
Thank you.
