- Joined
- 2 Nov 2005
- Messages
- 3,395
- Reaction score
- 245
- Country
Ok here is one that is just as basic which joint should not be done with PTFE gas or otherwise
Long Thread.
Pffft that was an easy one nam, it's always in the ACS. Now give us some hard ones.New someone like you would get it scatman was wondering what some of the others would come up with seeing as such a simple question as PTFE has become 4 pages
There's nothing to say you can't use PTFE on a long screwnamsag said:Ok here is one that is just as basic which joint should not be done with PTFE gas or otherwise
As i said sooey its basic but then again so is gas ptfe or normal and look where that led 2 eejits going through BS and **** at each other.
Is there any difference between using gas PTFE taps and more turns of standard PTFE?
normal ptfe is different from gas ptfe and something in the gas reacts with it and causes it to leak so gas grade ptfe should be used it has a slighty different make up so it does not react
Forget ptfe, use loctite 55, suitable for gas and water according to manufacturers.
ONETAP you have proved nothing and whittled on and on with a personal agenda against softas
Its simple you cannot use normal ptfe on gas it MUST be ptfe designed for gas that can be used. No where does it say IF normal ptfe used then use lots of turns. Simple
i have lost count of the number of leaks i attended when NORMAL ptfe was used and joints slackened off after about a year and p****d out gas.
