Hello, I am an electrician and I have wired a dwelling which is to supplied by a mobile generator. I performed all of my dead tests and everthing ok.
I have wired it up as a TT system, spike ect.
My tester won't allow me to carry out earth loop and Rcd tests.
There is voltage on both live and neutral outputs from the generator, are about 170 volts on the live and about 60 volts on the neutral.
These are both to earth. There is 230volts between the live and neutral.
Is this correct?
Also the generator is about 5 years old and has had repairs on it, eg the rectifier and the stator have been worked on, previously. As I was told by the owner.
Is this correct?
