- Joined
- 27 Jan 2008
- Messages
- 27,475
- Reaction score
- 3,323
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Since it is duel voltage it seems very likely I am correct and since using a double pole MCB then the neutral is one assumes protected. As to where to go from this point that is much harder, as said opening up the generator and doing a rewire making it single voltage would be ideal if the duel voltage is not required.
However if it does require duel voltage then making the house suitable is next move. As to what is required regulation wise I am uncertain. However there as some single width RCBO's on the market which although they don't monitor current through the neutral they do switch the neutral to my mind using them would be a good compromise leaving it as 70 volt between neutral and earth.
Lets see what others think?
