Yes but it does not help with the RCD tests, I can do the Zs (EFLI) using 2 probs but this cannot work with the RCD test, or I am wrong?Surely the neutral & earth are tied at the generator????
This is one option (see section 717 fig 717.1 page206) but you do not have to have a rod, you can use the van chassis as your earth ((this is done by the manufacturer), and this is the case I am talking aboutAlso it should really have a rod!!
Thanks, what in your opinion is the best way to test this.Sounds to me like the earth is floating, N and E probably aren't linked at the genny, so you should probably investigate this before going any further.
Just talked to the customer and he is going to buy a new generator, hopefully it will solve this part of the problem. I still have the RCD testing issue, do you think that if the earthing in the generator will be ok it will allow to run the RCD test?
