What do you mean, Matt? I don't need the controller?
I have to use the boost all the time pretty much.
What should I do here?
Not quite. The one Horstmann did before that one. It is called Horstmann Quartz Economy 7. Same concept.
right had a look, I would probably chance telling him to bring one with him its a knocking bet that its the controller
Matt
Matt
Matt
Matt
I would cancel him and order one yourself (from Wilkes for example). The new one will fit directly on to the old wire box (no wiring required it 'plugs in') again assuming that we know the lower immersion element is serviceable.
Ok, the one I posted repleaces the one you have.
Just to save reading the whole thread, do you have confirmed that the elements should both function?
When you advance the clock does the main element come on (ie can you hear anything like a kettle beginning to heat up from inside the cylinder if you put your ear against it?)
