Hi all,
Does any body have any experience about getting notifiable wiring work approved by a Building Control Dept?
Apologies in advance for length of post!
About 3 years ago I started to build a fair sized (7x10m) extension including shower room and kitchen. Initially I intended to get all the electrical work done by qualified electricians but as time progressed and I needed lighting and sockets to do building work I did most of the wiring myself.
Cooker and hood installation unit work and mains bonding were done by fully qualified electricians. I never did any work without researching the appropriate regulations and took photos of every stage. Much of the work is still open to inspection. In all there are 6 lamp fittings and 14 sockets.
Lately an electrician came to connect a cooker isolator switch/outlet and new 10mm cable (which I laid) to the consumer unit and commented that the work was good. So I asked if he could certify the rest of the work and he said no because unless he'd done the work he couldn't certify it which sounds fair enough. However, he said the local Building Control dept may do it for a fee "if they had anybody available."
Doe anybody know if Building Control would definitely do it and should the work be completed or open to inspection (some of it would be a pain to expose - like removing Fermacell building boards and panelling).
Many thanks
Many thanks
