Gillette blades
These days i use a Mach 3.
I’ve just gone back to them. I have an electric shaver and when the head is new, it really is as good as a wet shave. Unfortunately, despite using the correct cleaning/lubricating and charging dock, they only stay sharp for three months at best. They are supposed to last 18 months and at £45 a time, I’m fed up with replacing them.
I used an electric for a few years. Always aggravated my dome! Spots etc.
Cant beat a proper wet shave, with good quality shaving soap, brush and blade.
Back in the day, yes I used a DE, and bits of tissue stuck on the nicks - but I wouldn't use one now.
I did buy and try a DE, a few years ago, but only used it once - once was enough.
Maybe give it another shot? I tried a cheapo Baili one from Amazon years ago and it was hit and miss, then I tried the Wilkinson sword plastic DE which was a marked improvement. Then I made the upgrade to a Muhle R89 - rated as one of the best to begin with - this gave me decent shaves.
I now have a Fatip piccolo, but this is also hit and miss, I have a Parker semi-slant razor and this is the best shave I get now. There’s plenty of websites and YT videos if you want per to try again. One of the best ones is Mantic59/Sharpologist.com. Badgerandblade is a good forum too. Shavenation.com provides some great videos and advice.
It’s all about the preparation and finding a blade and cream that works for you. I currently use the body shop shave cream which is one of the best I’ve tried so far. As for blades: Wilkinson sword, Kai, Personna in my current range. I did like some Gillette ones but they’re made in Russia, so I don’t buy them currently.
I highly recommend an adjustable one from Shein - I had one, which didn’t last long as you can imagine, but gave me decent shaves and helped with my technique
Maybe you should try wet shaving again? See my above post.
I use the cheapest disposable razors I can find. A bag of 10 last me around 6 months.
Electric razors I find take 2 or 3 times longer to get a decent shave.
One of the advantages of an electric shaver is that you can shave while you shìt.,
Twice a week shave, head and neck as i have beard. And, i only shave 'with the grain' too. Makes for a pain free, spot free shave, most of the time!
For the closest shave, I cover each area, going all ways and multiple times. A good close shave, then lasts me a couple of days.
I've tried a variety of aerosol shaving foams, creams, and gels - I find gels work best for me, but little difference between any of the gels, apart from colour and smell, so I buy a really cheap one, Raze Sensitive, in a blue and white can, often sold by Home Bargains, for £1 a can.
A DE shave I can get a damn fine shave (dfs) or even a baby bum smooth (bbs) in 2-3 passes depending on which blade and razor I’m using.
Edit: even Gillette have produced a safety razor again with blades to suit.
Electric shavers always leave my skin a little raw, so I avoid as much as possible. I get a similar effect, though not quite so bad, when I try to wet shave in the washbasin, I get the best, easiest, and most comfortable shave, during and after - whilst having a soak in the bath. A bonus, seems to be - the blades last much longer, doing it that way too.
Electric did irritate slightly when I was younger, but as i got older I developed a thick skin. ;)
They're not for throwing across your face and neck, while trying to eat toast and putting your shoes on at the same time.
A good DE and being in no rush, that's the ticket (y)
Yes, there's the downside. Lack of flexibility. When travelling, I've often nipped into services for a quick electric shave in the bogs. Wouldn't combine shaving and driving at same time - though it's possible. Seen it done before. Same at airport, nip into gents for a quick shave. Not really feasible with wet shaving.
