The aircraft batteries are more dangerous than phone batteries
I will admit the polling of mobiles is heard less today as transmit powers have been reduced but they still does cause EMC problems with sensitise equipment. And the main problem is finding them. With a two way radio it only transmits when the PPT is pressed and one can easy see anyone using one on an aircraft but with a phone it polls all the time and does not need anyone to be talking on it to poll.I personally would ban all Iphones from aircraft.
For what possible reason?
I will admit the polling of mobiles is heard less today as transmit powers have been reduced but they still does cause EMC problems with sensitise equipment.I personally would ban all Iphones from aircraft.
Once out of the range of a cell sight the power goes to maximum and it polls more often so on aircraft it is a very real problem.
Ah, hospitals.However I got caught out in a hospital with a Nokia where I had set a reminder for an appointment.
There is precisely zero evidence that a mobile phone has any affect whatsoever on the flight critical systems of aircraft, modern or otherwise.
There is precisely zero evidence that a mobile phone has zero affect on the flight critical systems of aircraft, modern or otherwise.There is precisely zero evidence that a mobile phone has any affect whatsoever on the flight critical systems of aircraft, modern or otherwise.
They test them to ensure there is no problem.
You wouldn't want to find out there was a problem during a flight
The tests prove (?) that the effects of radiation from mobile phones on aircraft avionic systems are within safe and tolerable limits.
It's not just aircraft systems which are emc tested.
Practically everything else electronic in your house is emc tested.
Some of the avionic systems depend on receiving communications from stations that may be thousands of miles away ( aircraft in mid ocean ), The inverse square law of signal strength can mean the required signal is much weaker than the signal from a mobile on board the aircraft.
Car EMU systems do not have radio receivers in the critical control paths in the system.
A plane could survive a burning battery without any injuries to crew or passengers, a phone battery self igniting in a pocket could cause serious burns and chemical contamination ( poisoning ) to the person.The aircraft batteries are more dangerous than phone batteries
