"Never look into the laser with your one remaining good eye"My favourite safety poster was (all in black except for the words)
Afraid of the dark?
Always wear your safety glasses.
Afraid of the dark?
ericmarK said:Do museums have a dispensation?
Another H&S violation story - but not a trick played on the innocent.
My dad was a printer all of his life, and at one time they used to use soldering irons to joint etched zinc printing plates. I've tried to find an image on Google, but failed.
Imagine something 30-40cm long, with a wooden handle, and a metal shaft with an end like a small, thick, blunt axe head or tomahawk. That would be placed on a gas burner until it was hot enough to be used to butt join considerable lengths of plate together before needing to be reheated.
The mad ones used to hold a hot iron by the handle, and toss it up into the air, and as it came down, spinning, would catch it.
Hopefully by the handle.
My grandfather's soldering iron, c1910. I still use it occasionally (for non electrical joints!) - goodness knows what he used it for!Imagine something 30-40cm long, with a wooden handle, and a metal shaft with an end like a small, thick, blunt axe head or tomahawk. That would be placed on a gas burner until it was hot enough to be used to butt join considerable lengths of plate together before needing to be reheated.
Kind Regards, John
The science museum in London has a one million volt generator built from two stacks of capacitor plates criss-crossed with selenium rectifiers. It's a voltage multiplier, originally driven by some unseen high voltage AC supply under the floor. You can walk right up to this thing and almost underneath it. So there I am, looking up at a megavolt capacitor stack - and no shorting link!
Well, it wasn't really a question - but you're right, there's no telling what it might start around here!goodness knows what he used it for!You should not ask questions like that on here
something like this?
I recall during my apprenticeship, using this to solder up tundishes, tin drip trays and the like.
