It seems the government got it wrong, they have linked to BS 7671 except for what is considered as the electrical installation, so until a court rules there is no answer.
I was say anything which would be considered as electrical equipment is not an electrical installation. The installation takes electrical power to point of use, and the equipment uses it.
Where is gets a little harder is when the equipment is made from many parts, and what to class the bits that joint it, be it a power supply and lamp, or thermostat and immersion heater the cable which joins to two parts has to be tested so is it a lead set and tested with the inspection and testing of in-service electrical equipment or is it part of the electrical installation and be included in that report? For ease I will call it PAT and EICR, if it comes under PAT testing then can be class II and if under EICR with the exception of the pendent part of a lamp then can't have class II, but this leaves light fittings as being part of a PAT test which does not seems right.
So reading what has been said so far, it would seem where a number of cables connect a wiring centre to a boiler then only one of those cables needs to carry the earth, so the other cables could have the earth wire over marked, but where a single cable supplies a thermostat and the like an earth must be run, when using low voltage.
How about extra low voltage, be it a light connected to a power supply, or a door bell, or the 24 or 48 volt supply to a thermostat, does it still require an earth, I would not have dreamed running an earth to the door bell, I would say it is SELV and it would be against the regulations to earth it, but for it to be isolated we look at the sign
means safety isolating control gear with short circuit protection which is made up of:-
which means a transformer and
means isolating transformer
means non short circuit proof isolating control gear
means short circuit proof isolating control gear. So the big question is where the boiler used 24 volt control what type of supply does it have? I selected a
random boiler installation manual and looked to see what is said about the 24 volt supply, it calls the 24 volt supply low voltage although it should be called extra low voltage and I could find nothing to say if SELV, FELV, or PELV so no idea if earth required or not.
So still non the wiser.
