Hi all,
I have a bit of an issue planning the wiring for my new outside lights.
We are going to use some low voltage LED lights in the garden, on 2 circuits.
There is currently a switch for the 1 outside light, and I want to replace this with a 2gang switch. This switch is on the downstairs lighting circuit, which is not RCD protected.
We have a 12 year old MK CU that is full, and the RCBO's for it take up 2 spaces, so we cannot convert the lighting circuit to use an RCBO.
So my proposed solution is to turn the single backbox in the wall for the outside light into a double, fit 2x dual pole switches in a grid plate, and fit an RCD in the grid if such a thing exists. So far I cannot find one.
Can anyone suggest where to find one, or some other genius solution?
