Yes, that all appears to make sense, and is very probably correct.G4 holder has no clip restraint, likely accepts either lamp type. ... GU4 holder has some form of clip attached, designed to lock in GU4 lamps,would maybe also take a G4 lamp subject to size of lamp base fitting between clips, or possibly fitting and making the clip redundant. ... Main point of GU in my opinion, to support the heavier GU type lamps from pin withdrawel and possible arcing
Indeed. As I implied, I also strongly suspect that is the case. However, in this case I suppose there is more 'excuse', in as much it has proved a bit of a mission to try to ascertain what is correct!As with the "low voltage" and "transformer" sagas , I suspect a lot of the G and GU lamps and holders are wrongly described
Kind Regards, John
