Heat Greek vs Skill Builder mainly heat pump, but some reference to condensing gas boilers.
I've never seen a heat pump
Look like every aircon unit in every film you've ever watched
I can't see how they are cost effective
My system cost me 5 grand, and the RHI paid me 7
I can't see how that's not cost effective!
Can you get someone to fix short notice?
I called Vaillant out once, circulator pump issue fixed under warranty
How reliable?
I've never touched it. "Servicing" it amounts to washing any crap out of the vanes. Never done that either. Been churning out warm water for 8 years now
Saving worth the cost of installing?
I don't have gas. Monobloc systems can be mostly DIY installed and maintained. Overall I'd estimate mine's been cheaper to run than a gas boiler
I was thinking "passivhaus" standards.
Then you don't need a formal heating system at all, and certainly not one as expensive as an HP. Keep a couple fan heaters in a cupboard
Insulation does not have to be particularly good
Insulation should be particularly good in all properties and (in tandem with straight proofing) should be the primary focus of any upgrade, not the heating system
If you get the insulation right you don't need heating, and both wallet and planet thank you ongoing
There are some tables out there, but at 40% humidity we humans need a stable air temp of 17.6 c to feel comfortable and at 65% we need 19.7c.
The colder the air temp the lower the humidity i.e. cold air holds less moisture. This means body sweat can evaporate more easily. Increased humidity means less evaporation and thus it is harder to cool down. Since the focus is to stay warm during the winter then surely you want to increase humidity and lower evaporation, not increase it ?
